355 to 383
Old Mar 14, 2010 | 08:52 PM
theoryTim's Avatar
355 to 383
Hi people,
I recently have a 355 which I know is a 350 block bored .030 over. I want to upgrade my engine and stroke it out using a 400 crank (making it a 383ci)
My question is, can I use the same block that my 355 is? What type of machining will I need to do to it if I can?
Do I just buy a stroker kit with .030 pistons? Any help is appreciated.
Old Mar 14, 2010 | 08:54 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Re: 355 to 383
the block will need to be bored over again, a 400 crank is needed and bigger pistons to match your bore size.
Old Mar 14, 2010 | 08:56 PM
theoryTim's Avatar
Re: 355 to 383
Thank you.
What is a good common bore size? Taking i'm not really sure if I want to keep my current heads on there, so i'm open to suggestions.
I want this engine set-up to have speed/power, but to also be as friendly as possible on gas.
Old Mar 14, 2010 | 08:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 355 to 383
If the cylinders aren't excessively worn, you may be able to use .030-over pistons agian. No way to know without taking it apart and inspecting.
Old Mar 14, 2010 | 09:02 PM
theoryTim's Avatar
Re: 355 to 383
This block has freshly been machined with new bearings/piston and rings/etc and what not and has way under 1k miles on it...
For sure something I will inspect once I get into this build. Building my ideas up. I see that most 383 kits come with pistons anyway.
Old Mar 14, 2010 | 09:12 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 355 to 383
It's normal to have pistons in a kit. To change the stroke, you need a new crank, and new rods or pistons.
Old Mar 14, 2010 | 10:22 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Re: 355 to 383
If you have new pistons, rods(or reconditioned) and a freshly built motor all you need is a crank and some clearance. You can reuse your pistons rods and rings if there in good shape, with only 1k miles they better be.
Old Mar 14, 2010 | 10:31 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 355 to 383
No, you can reuse the pistons or the rods, not both. At least one of them has to change.
Old Mar 15, 2010 | 07:01 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Re: 355 to 383
Why? As lomg as the skirt doesnt touch whats the problem
Old Mar 15, 2010 | 07:12 PM
SeanW's Avatar
Re: 355 to 383
Where do yo think the extra .252"/2 stroke is going? Above deck, thats where.
Old Mar 16, 2010 | 10:57 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
Re: 355 to 383
you have to the rist pin location in the piston up or use a shorter rod.
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
