305 and 350 swap
Old Mar 17, 2010 | 10:03 PM
Shane4524's Avatar
Car: 1986 Camaro IROC Z28
Engine: 5.0L 305 TPI
305 and 350 swap
To start this of this is only an idea right now.
I have a 1986 Camaro with a 5.0L 305 TPI. Then I have a 1991 Chevy Silverado with a 5.7L 350 EFI.
Is it possible to swap these motors?
Old Mar 17, 2010 | 11:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes. The main "issue" is the center two intake manifold mount bolts on each side are at a different angle on the '91 than the '86.
Old Mar 21, 2010 | 11:04 AM
Shane4524's Avatar
Re: 305 and 350 swap
How big of an issue would that be?
Old Mar 21, 2010 | 11:38 AM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
the easiest solution would be to buy a holley stealth ram for vortec heads, or do what I did and get a vortec carb intake like the Weiand Stealth that I have.
Old Mar 21, 2010 | 05:02 PM
daboom916's Avatar
im new here and am interested in same i have a 87 z-28 305 4bbl and have a 98 5,7 from a c1500 cuz i was told the vortec was more powerful but can i make it carb instead of fuel injected? heard there might be a fuel pressure problem due to the vortec head requirements
Old Apr 7, 2010 | 10:19 AM
Shane4524's Avatar
How big of a hassle would that be?
Old Apr 7, 2010 | 11:38 AM
fiream's Avatar
Engine: 400HP 350
En 1 intake bolts mount at a 45 degree angle. The vortex bolts mount vertical, down I to the heads. So you can't use an "old style" gen 1 intake on a vortex head.
Old Apr 7, 2010 | 05:06 PM
five7kid's Avatar
You need a Vortec intake manifold. Available in carb style.
Easier to get a manifold that fits, but many have done their own modifications to those 4 bolt holes in the intake so that the bolts can be installed.
Old Apr 7, 2010 | 05:28 PM
fiream's Avatar
Engine: 400HP 350
Vortec
Gen 1
Old Apr 7, 2010 | 11:41 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
The engine from the 91 truck would be an L05 350 and NOT a Vortec engine. Your intake would not bolt right up. 1) you would need a new intake, or 2) you would need to enlarge the center two holes in the intake for the bolts to go in. Going to a vortec headed engine you would need a new intake.
Old Jun 8, 2010 | 12:21 AM
Shane4524's Avatar
When you say enlarge the center two holes in the intake... Is that a big issue and what else would i have to do?
Old Jun 8, 2010 | 01:56 PM
five7kid's Avatar
It isn't a big issue, and that's all you would have to do to get the base to mount to the later engine.
You might be able to trade your base with someone who has an '87-up base and wants an '86-earlier base.
Old Jun 10, 2010 | 11:13 PM
Shane4524's Avatar
So once i do that I can slap the '91 350 right in there?
Old Jun 17, 2012 | 08:31 PM
snoman8787's Avatar
wat about the computer would u have to swap the computer and would the connector b the same but its to a 91 silverado and 89.
Jake_92RS
Jan 28, 2020 10:37 PM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
