LT1 heads
Old Mar 23, 2010 | 04:41 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
LT1 heads
Hi i am wondering since i want to buy a z28 but it needs a rebuild engine and i have a L98 from a camaro and i was wondering if i can bolt on the heads from the LT1 to it for i could buy the car
Old Mar 23, 2010 | 06:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"Bolt to"? Yes.
"Work"? No. At least, not without extensive (and expensive) modifications.
Old Mar 23, 2010 | 06:08 PM
five7kid's Avatar
Just curious, where did the LT1 heads come from? What car are you thinking of buying specifically (year, model, engine, etc.)?
"Norwalk, CA" means it has to be emissions-legal, and a L98/LT1 hybrid would not be.
Old Mar 23, 2010 | 06:11 PM
five7kid's Avatar
If I'm understanding this correctly, you're looking at a '93-'97 Z28 that has a blown engine (but the heads are okay), which you would buy if your L98 shortblock would work in it. Basically, the answer is "no", primarily for the emissions reasons above.
You could make it run with TPI induction/controls with modifications to the LT1 heads, but no way no how would it pass emissions inspection.
Old Mar 24, 2010 | 05:07 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: LT1 heads
Yes you are right i want to buy a 4th gen camaro and put my L98 block with the heads of the Lt1 as for the smog i got some one that could pass it for me no matter what so that really isnt a problem for me
Old Mar 24, 2010 | 05:51 PM
five7kid's Avatar
It's just not worth it. If you want the car, find a good LT1 for it. They aren't that expensive. Sell the L98 to finance it if you have to.
Old Mar 25, 2010 | 01:19 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: LT1 heads
I will do that around how much are the L98 worth
Old Mar 25, 2010 | 01:29 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LT1 heads
L98 shortblock is just a generic flat top 350 with 2 bolt mains and 1 pc RMS. A good one usually goes for $200 or less depending on the miles
Old Mar 25, 2010 | 04:54 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: LT1 heads
Its because i already replaced all the gaskets and the rings and rebuilt the heads
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Sep 2, 2015 06:27 PM
midge54
Aug 29, 2015 09:51 PM
Redwhisper
Aug 26, 2015 05:02 PM
