Wiring Harness Questions w/pic
Old Mar 23, 2010 | 06:14 PM
howy03's Avatar
Car: 1985 Pontiac Trans Am
Hoping u guys can help me with some questions and suggestions on what i can remove in my Harness.I searched and read lots of posts including TGO member pockets ltx ls harness swaps these were a little out of my league but I Know my harness is simple compared to some.I have a 85 TA and I am swapping in a 355 non cc.I removed the ecm harness know I Just have some questions on my harness.I labeled theses items in the pic.#1 O.k. #2Pink and white distibutor wires where will these hookup on my new non cc hei. #3Should i remove this wire? #4 and #5 these just hookup to senders to retain factory guages correct?#6 altenator plug with jumper wire attached.can I just remove the plug and jumper to hookup to an aftermarket 1 wire altenator?#7 E choke wire will use this on my new e choke carb.#8 and a jumper plug on #9 were attached to the firewall near the blower.I think these are for an ac option.?can I remove theses? also #8 had a ground to the firewall do I need this or can I use the ground strap from the head to the firewall?#9 purple starter wire is ign wire? and the red has a few jumper wires with factory splices.I think this wire feeds the fuses and 12v power to the car.is this right? I know this is long but I figured do it as one post. Thanks for any feedback Howard
Attached Thumbnails Wiring Harness Questions w/pic-labeled.jpg
Old Mar 23, 2010 | 07:53 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Wiring Harness Questions w/pic
Cant help you with the carb controls
Coolant and oil pressure sender hook directly up to the senders
Im not familiar with 1 wire univ alts. The old alt wire is a fused 12v IGN source. If the new alt is excited by a simple 12v IGN, then sure. Some alts are excited by a lower voltage and require a resistor. For those, 12v will make them work, but they burn out after a week or so. Make sure before you burn the alt up
Grounds can be moved wherever you please. Just be sure in the end you have the body connected to the engine with some sort of ground strap all leading back to the battery
Purple is starter solenoid wire. This goes directly to the small lug on the starter
Two big red wires are main 12v constant for the interior and front harness. Without those, your car's electrical system is dead. I like to move these off the starter and to a power dist block located somewhere in the engine bay
Good job on stripping the harness, looks very clean and neat. Refer to the carb board if someone doesnt fill in the choke wire functions here. You may get by using a factory diagram
Old Mar 24, 2010 | 01:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The carb wires appear to be properly identified. Didn't you tag them when you removed them?
The pink ignition wire will go to the "BATT" terminal on the coil-in-cap HEI distributor, and white to "TACH".
Old Mar 24, 2010 | 05:02 PM
howy03's Avatar
thanks guys, five7kid I did label everything as I removed it I am just wanting to make sure everything will basically work the same when i hookup to the new engine..I am still wondering whats differrant in a one wire and 3 wire alt. hookup I would like to convert to one wire.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
