1989 Camaro mount swap?????????
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
You're talking about the mounts that bolt to the engine, right? They are different. There have been threads in the past discussing this, but I can't tell you off the top of my head which is which.
While it can be a bit of a challenge to get them to fall into place even when everything is right, if you can't get it to even get close, try switching them from side-to-side and see if that helps.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
