Engine swap help
Old Apr 3, 2010 | 09:34 PM
jcon104's Avatar
Engine swap help
i have a 1991 z/28 with a 305 tpi and 700r4 tranny, i swapped in a 350 block from a 1985 chevy truck, and installed pedals and a 5 speed world class tranny, i have all thge wires hooked back up to were they were on the 305, when i turn the key absoulelty nothing happens, I decided to jump in form the starter and it ran . I thought it might be a computer problem do you have to swap out the computer when going from a 305 automatic to a 5.7 manual ?
Old Apr 3, 2010 | 09:39 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
Re: Engine swap help
Originally Posted by jcon104
i have a 1991 z/28 with a 305 tpi and 700r4 tranny, i swapped in a 350 block from a 1985 chevy truck, and installed pedals and a 5 speed world class tranny, i have all thge wires hooked back up to were they were on the 305, when i turn the key absoulelty nothing happens, I decided to jump in form the starter and it ran for about a minute and then shut off. I thought it might be a computer problem do you have to swap out the computer when going from a 305 automatic to a 5.7 manual ?
check all your wiring in the pedals(brake switch and clutch switch) remember that the 305 with 700 has the park lock up switch which the computer needs to start the engine... also check the vats wires... is ur check engine light on? diagnose the codes if it is
Old Apr 4, 2010 | 10:01 AM
jcon104's Avatar
is the park safety switch you are talking about t the same thing as the neutral safety switch??
Old Apr 4, 2010 | 10:02 AM
jcon104's Avatar
Problem solved turned out to be the starter relay switch thanks for the help though
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
