2010 camaro engine in a '91
Old Apr 11, 2010 | 12:57 AM
sangre_azteca21's Avatar
Car: 1991 Chevy Camaro RS Lt Edition
Engine: 3.1 L
Transmission: auto
IS IT POSSIBLE?!
i wanna take out my 91's v6 and put a more powerful engine and i see people putting in ls1's and on and on, but why not a 2010 camaro engine? i wouldn't mind dropping a 2010 camaro v6 into my 91, but is it possible?
Old Apr 11, 2010 | 01:06 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Re: 2010 camaro engine in a '91
anything is possible...
do you have the cash and knowledge to make it happen?
Old Apr 11, 2010 | 01:07 AM
Engine: 3.1 L
Transmission: auto
i have the cash.......
Old Apr 11, 2010 | 01:14 AM
Engine: 3.1 L
Transmission: auto
i have the cash to buy a 2010 camaro v6 engine and all that fun stuff but what exactly do u need, wouldn't u need a transmission that goes with that engine and all the electronics that go with that engine? yeah i dont know squat about engine swaps
Old Apr 11, 2010 | 01:19 AM
Stephen's Avatar
Car: 87 GTA
Yep. You'll need all that to go along with the engine.
You'd be ahead just to pick up a totaled 2010 Camaro from the junkyard, then pull the engine, tranny & PCM. That way you'd get all the wiring that you'd need.
Old Apr 11, 2010 | 01:23 AM
Engine: 3.1 L
Transmission: auto
so all that really is needed is the engine, tranny, and pcm, thats it? nothing else i should know before i go off and do something stupid with a lot of money?
Old Apr 11, 2010 | 01:52 AM
Engine: 450HP 355
Transmission: TH350
considering it hasn't been done i'm sure you'll run into lots of other problems...
the 3.6 is direct injected so you'll need the correct fuel pump, probably all new fuel lines, the entire harness, computer, etc... You may also have to modify your stock K member for clearance and make motor mounts.
Old Apr 11, 2010 | 02:03 AM
Engine: 3.1 L
Transmission: auto
ok well how about another way to add more power to my current v6?
Old Apr 11, 2010 | 10:05 AM
Engine: 450HP 355
Transmission: TH350
check out the stickies in the V6 section...
Old Apr 11, 2010 | 12:22 PM
superbro3000's Avatar
Car: 92 rs,70 chevelle ss,86 buick gn
Engine: 305 tbi,402 bb,turbo v6..what else?
Transmission: 700r4,muncie 4 speed,stock
Axle/Gears: 3.73,4.11,stock
....why ruin a perfect bowtie??
just kidding
sounds like a good idea
i would try it
Old Apr 12, 2010 | 10:02 AM
SeanW's Avatar
You'd be ahead just to just up a totaled 2010 Camaro from the junkyard, then pull the engine, tranny & PCM. That way you'd get all the wiring that you'd need.
I'm not sure what "just to just up" means but i am guessing you meant up and buy the whole wrecked car.
If so i couldn't agree more. Having done some swaps i can tell you three things. Its never cheap, its never easy and there will always be some part(s) you need that you didn't think you would. Having the whole donor car is the way to go.
Old Apr 12, 2010 | 10:04 AM
SeanW's Avatar
A 3.8 regal/GN turbo swap would be interesting, powerful and probably a lot easier.
Old Apr 12, 2010 | 10:06 AM
Stephen's Avatar
Car: 87 GTA
I meant "You'd be ahead just to PICK up a totaled......"
Yes. Grab a complete car, take what you need, then resell the rest.
Old Apr 12, 2010 | 10:12 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
If you pick up a 5th gen for the swap do the dash swap too. You can be the first to do it all and have something to talk about with friends once you get it up and running. Get one that is t-boned or better yet rear ended, then you can have the complete dash and seats
Old Apr 12, 2010 | 10:16 AM
Stephen's Avatar
Car: 87 GTA
Yes & no.
That would essentially be the same as a TTA, but AFAIK, the heads on the Buick V6 had to be changed out, because they wouldn't fit between our strut towers. And a different turbo was used. Dunno why, but maybe the Buick one wouldn't fit? The one Pontiac used was better, to go with the heads they used?
Old Apr 12, 2010 | 11:26 AM
Engine: 3.1 L
Transmission: auto
hmn........ well i'll consult my mechanic and see what he has to say......
Old Apr 13, 2010 | 12:26 PM
Engine: 3.1 L
Transmission: auto
can u really put a 2010 camaro dash in a 91? i know u can probably put a 91 dash on a 85 or any other thirdgen
Old Apr 13, 2010 | 01:09 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
Don't forget things like instrument cluster would have to have a custom setup as the ECM wouldn't work with your current setup. The gas pedal will have to be changed as all the new cars are drive by wire and have no mechanical linkage.
You'll also need the transmission from the 2010 donor, and perhaps a custom drive shaft.
If you have the money go for it. BUT IMHO it's not worth the cost of materials time and trial and error to do it all. A LS1, LS6 swap is going to be easier to do and all the info on doing it is out there.
Old Apr 13, 2010 | 02:49 PM
sargenewk17's Avatar
Car: 92 Camaro RS
Engine: LS2
Axle/Gears: 12-Bolt with 3.73
you can do whatever you want, don't let anyone convince you otherwise. Somebody's gotta be first to do it. If you've got the resources and the "want to" then go for it.
Old Apr 13, 2010 | 04:34 PM
Night_blade897's Avatar
dude, if your a millionare id say DO IT, go buy a new camaro and get everything out of it. cz that would be one SICK @$$ thirdgen =]]
Old Apr 13, 2010 | 04:39 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
