Blew rod through cylinder, suggestions on what to do next
Old Apr 16, 2010 | 09:59 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
My friend blew a rod in her 85 Firebird a few years back, wasn't there to hear the whole story, I just got bits of what the mechanic told her. It was a 2.8 L and I'm trying to figure out where to to go from there because I am going to HATE to see that car go. I was hoping I could get some suggestions on what would be the smartest choice from there, money is pretty tight.
Old Apr 16, 2010 | 10:06 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Blew rod through cylinder, suggestions on what to do next
Call around to all your local salvage yards. and '85-'89 Camaro 2.8 will work, and you should be able to get the short block assembly for under $150. Or a long block assembly for under $200. Including taxes and other little fees. Considering the price of head gaskets, and the challenge of adjusting the rockers, I'd go with a long block assembly if at all possible.
Old Apr 17, 2010 | 06:01 PM
Mr Froman's Avatar
Alright, so say we get the long block assembly, what has to be done before the engine can be dropped in?
Old Apr 17, 2010 | 06:04 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You just transfer everything else from the ruined engine to the replacement. The manifolds, the water pump, the front accessories, it's all very simple.
Old Apr 17, 2010 | 06:11 PM
Mr Froman's Avatar
Awesome. I just worry about the other engine also going because it'll be just as old.
Old Apr 17, 2010 | 07:49 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Age isn't a killer of 2.8 rods. Excessive RPM is, and detonation is, but not age.
Old Apr 18, 2010 | 12:24 AM
Mr Froman's Avatar
Should I worry about gaskets+seals?
Old Apr 18, 2010 | 12:48 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
If they look like they've been leaking, replace them.
The later 3.1l V6's were a little more stout. Still can't put it in 1st, floor it, and see how fast it will go down hill, but they are less likely to develop cracks with "normal" use.
Old Apr 18, 2010 | 06:36 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If you're gonna buy a long block, I see no outstanding reason to think about the head gaskets so long as the head bolts have never been loosened with tools. But expect to replace every other gasket.
Old Apr 18, 2010 | 02:30 PM
Mr Froman's Avatar
I really appreciate the help. How much could you expect to pay to replace the gaskets?
Old Apr 18, 2010 | 03:26 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Use Fel-Pro or you WILL have leaks. Don't use any silicone either. If you want to use some chemical, use Edelbrock's Gaskacinch.
db057
Apr 28, 2019 07:45 AM
64goatman
Sep 9, 2015 01:09 PM
Jk_Under
Sep 8, 2015 08:13 AM
tgp1990
Sep 4, 2015 06:24 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
