ls1 swap vs 350 ram jet.
Old Apr 24, 2010 | 10:23 AM
pestrada38's Avatar
Car: 1990 FORMULA WS6 T-TOPS
Transmission: BORG-WARNER T5
Axle/Gears: BORG-WARNER 3.42
Is it cheaper just dropping in a 350 ram jet than doing a ls1 swap? The tranny bolts right to the 350 ram jet. HP is rated about 320 and hp on ls1 is about the same. I thinking of going this route. I know it could be done cause I saw it on a 92 rs on high tech.
Old Apr 24, 2010 | 12:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
LS1/4L60E drop-out - $2k-$3k
LS1/4L60E swap mounts - $200
Exhaust modifications - $500 (assuming you use f-body exhaust manifolds)
Misc. swap parts & stuff (hoses, cables, air inlet hoses, wiring stuff, reprogram PCM to eliminate VATS, rear O2 sensors, etc.) - $1000 (can be done for less)
Total: $5k
Ram Jet crate engine (350 gross flywheel HP vs. LS1 320 net flywheel HP) $6k (by the time you pay for the engine, tax, freight, etc.)
Misc swap parts - $300 (it's always more than you plan on it being)
Total: $6.3k
Both of the above assume you will have to upgrade the cat-back, so that's a wash between the two.
LS1 advantage in driveability, response to performance mods, tuneability - Priceless.
Frozer!!!
Jan 19, 2024 04:55 PM
xkingcodex
Feb 12, 2020 07:43 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
