CAMSHAFT for 350sbc????
Old May 4, 2010 | 12:01 PM
fbirdformula91's Avatar
hey all,
what would be a good cam, that'll give me a nice choppy sound for a 350 small block?
Old May 4, 2010 | 01:21 PM
the phoenix's Avatar
Car: 1985 Pontiac Trans Am - PROJECT
Engine: 412 c.i. SBC / 6.75 L
Axle/Gears: Borg Warner 3.27
Re: CAMSHAFT for 350sbc????
There is a lot you have to look at as far as heads and whatever to get everything matched up well, but I've always been a fan of Comp Cams for ANY engine size. I am using the XE284 in my 412 and it sounds GORGEOUS... I think the specs call for a stall of 2750+ for the 350 so you may need to swap stall convertors...
Old May 4, 2010 | 02:58 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
What is the cam going in? A EFI or carb'ed motor? Stock motor or otherwise? If you just rush into the lumpy cam decision without also pairing and matching it with all the other affected mechanical and electrical components, your heading for disappointment. List your specs / build and go from there.
Good luck
Old May 5, 2010 | 03:06 PM
im not sure of the specs yet, I just finished tearing it down and it's going to the machine shop next week, but it's a 69 sbc 2 bolt main and it's goin in my 91 formula that currently has the 305 tbi
Old May 5, 2010 | 09:11 PM
houston_boss's Avatar
Car: 1986 IROC-Z
Engine: 305 TPI - 350 in the works!
Comp cams XE268H seems to be a fairly popular choice. Its the one ill be using and I believe is the most aggresive cam for a stock converter.
However, it does ultimately depend on the other components of your valve train.
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
