L31 crankshaft question
Old May 14, 2010 | 12:41 PM
mmyers_417's Avatar
Car: 88 formula; 06 cobalt ss
Engine: 305 tpi; 2.4 ecotec
Transmission: WC T-5; F23
Axle/Gears: 3.45 posi; 3.84
I recently bought a L31 vortec long block that im gonna put a HSR on and put in place of my 305 but i hit a major roadblock. While tearing the motor down to put in the forged pistons i noticed that the ******* who sold me the motor forgot to mention he spun a bearing (said car was wrecked and his son almost died, ya ok pulled me in like a sucker) so now i paid $500 for a motor that i still need a crankshaft for because the damage to the crank is bad about a 1/16 of an in of material gone maybe more. So now i need a new crank but some one near me on craigslist has a crankshaft from a 350 goodwrench motor for only 75 bucks it looks brand new would this crank work (im assuming it 1 piece rms but u guys would know more than me about them motors i never looked into them)? Also is it the same strength as the one i have because i heard the L31's have good cranks and rods any help is appriciated thanks.
Old May 14, 2010 | 05:44 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: L31 crankshaft question
No, the Goodwrench 350 uses the 2 piece rear main seal. There are adapters available, but they're not worth the cost. have you even checked your local salvage yards? Any '87-up 350 crank will do.
Old May 14, 2010 | 07:05 PM
mmyers_417's Avatar
ok thanks for the info that crank on craigslist was cheap and brand new so i was gonna try to push up on it but ill have to check the salvage yards for one
Old May 22, 2010 | 11:21 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
I believe any 87 up 305 crank will also work but require a balance, But a 1pc RMS 350 crank shouldnt be a hard thing to find.
Old May 23, 2010 | 12:18 AM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
wouldnt 305 and 350 cranks have different counterweights?
Old May 23, 2010 | 02:11 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Same casting, different cutting for balancing.
Old May 24, 2010 | 05:27 PM
Car: 1979 Malibu
Engine: Blown LSx
hence my comment about needing a balance...
Old Jun 28, 2010 | 02:46 PM
mmyers_417's Avatar
well i just decided to buy an eagle crank and call it a day i figure it will hold up better too thanks for the help tho
Old Jun 28, 2010 | 10:56 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
wise choice.
Old Jul 2, 2010 | 05:08 PM
Pocket's Avatar
Car: 91 Trans Am
Hopefully you dont have the common Eagle crank failure where the first rod journal likes to break off
84z96L31vortec
Aug 20, 2017 12:16 AM
TEEZER TA
Aug 30, 2015 06:35 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
