350 tpi engine pull, wiring harness connectors
Old May 17, 2010 | 08:31 PM
rockstar08's Avatar
Car: IROC-Z
Ive read a few other posts but without any definitive answers.
I am in the process of disconnecting connectors, mounts, hoses to remove my 350 TPI/Auto. I have removed:-
1) A/C compressor, ( to the side )
2) TPI Plenum, runners, baseplate ,rails, injectors
3) Distributor
4) Radiator
I notice that the pax side engine wiring loom goes through the a.i.r / a/c bracket then down to the starter motor. Does this need to be disconnected form the starter and removed from the engine prior to removing or can it stay with the block? do I just need to unplug the connector from the firewall near the brake booster? is that the c100 connector?
I believe next i need to remove:-
5) Bellhousing bolts
6) torque converter to flexplate bolts
7) engine mount bolts
Am i ready to pull then or not, I am going to be doing it by myself, so I don't want to damage any wiring/harness connectors..
any advice appreciated..
Old May 17, 2010 | 09:51 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 350 tpi engine pull, wiring harness connectors
If the engine is coming out, then drape all the wiring over the engine and pull it as one big piece
Old May 17, 2010 | 11:30 PM
rockstar08's Avatar
Car: IROC-Z
don't really understand this..
Old May 18, 2010 | 07:34 AM
Omerta88's Avatar
Car: 83 Bird
Engine: 454
Transmission: TH400
your best bet is to unplug anything you think you should better to un plug unneeded stuff then to brake it....your right on track with it jus take your time and suport the motor before removeing the mounts.....lift slow and keep watching for missed connections as you lift it....o and dont forget power steerin lines
Old May 18, 2010 | 09:51 AM
Pocket's Avatar
Car: 91 Trans Am
Remove everything together as one piece
Old May 18, 2010 | 04:11 PM
Omerta88's Avatar
Car: 83 Bird
Engine: 454
Transmission: TH400
aaa very nice...lol
Old May 20, 2010 | 10:45 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
ha ha ...... that works.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
The_Phoenix
Sep 3, 2015 10:56 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
