2.8 to 4.3 vortec swap need major help
Old May 25, 2010 | 01:20 PM
timmyt649's Avatar
Car: 1989 CAMARO RS
Engine: REBUILT 350 AND BORED 40 OVER
Transmission: 350 TURBO WITH MILD **** KIT
i need as much help as possible i have a 1989 camaro rs im putting a 2000 s10 exterme motor in both automatics i just need as much help telling me how to do it what i need and all i need to do this on a CHEAP BUDGET thanks
Old May 25, 2010 | 01:25 PM
JuggaloRon's Avatar
Car: 86 camaro berlinetta
Engine: 2.8, soon to be 3.4 w/ turbo plans
Transmission: 700r4(rebuilt in jan. '10
Axle/Gears: stock 3.23 open
Re: 2.8 to 4.3 vortec swap need major help
what's your current engine in the camaro?
Old May 25, 2010 | 01:33 PM
timmyt649's Avatar
Car: 1989 CAMARO RS
its a 2.8 v6
(original motor)
Old May 25, 2010 | 02:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Is the S10 4WD? If so, I doubt you'll be able to use the transmission. You certainly won't be able to use the Camaro transmission.
Do you have the whole S10? Hope so.
I don't believe I've heard of a member doing this specific swap. I would guess that you're looking at fabricating engine mounts and exhaust, and doing the usual grafting of the S10 harness into the Camaro.
Old May 25, 2010 | 03:02 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
^^^He said it was an extreme so it wont be a 4X4 I don't think. The motor mounts are the same as a small block Chevy on the 4.3 so you will have to get 3rd gen V8 mount pads(I could be wrong) but I don't have a clue on the wiring or computer.
Mark.
Old May 25, 2010 | 03:04 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
What's different about the motor mounts? They are both V6 motors, have the mounts changed over the years?
As far as what you'll need goes, a 2wd trans from a vortec v6, the crossmember, trans mount, wiring harness and computer.
I imagine the computer is a standalone engine management system so you'll just need to follow the main harness back to the computer (which on my 97 vortec k1500 is under the hood). You want to take every wire that runs to the computer. You will also have to change the steering columns because some of the wiring for the computer runs to that or rewire it yourself to an on/off switch. On the 80's fuel injected full size trucks, its pretty simple. I have never done it on a newer vehicle though.
Old May 25, 2010 | 03:11 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
^^ The 2.8 is a 60 degree V6 and the 4.3 is a 90 degree V6 so the mounts are different I think.
Mark.
Old May 25, 2010 | 03:29 PM
five7kid's Avatar
The 2.8 and 4.3 are completely different. The only things they have in common are the arrangement and number of cylinders.
The earlier 4.3 mounts are the same a V8, but aren't in the same place. Fabrication required - the typical approach is to test-fit the engine and transmission, get the transmission located by hooking it to the crossmember, setting the engine down on the K-member, and marking where the mounts need to go. However, I'm not familiar with the 2000-up 4.3's. I'd guess fabrication required.
You won't need to change the steering column if you program out VATS.
Old May 25, 2010 | 04:26 PM
JuggaloRon's Avatar
there was a company making 350 to 4.3 mounts for anyone looking to down grade from a v8 to a v6 for better handling. i believe i saw it in sport truck or another mini truck magazine. but as said above, you'll need motor, tranny, and computer. you'll most likely need a custom driveshaft and you'll have to relocate the tranny crossmember. i thought of doing the same swap but realised it would be too much work. if you do it successfully, me and probably a few others would love to see a well documented thread on this.
Old May 25, 2010 | 05:02 PM
five7kid's Avatar
2000 4L60E will be the same mount as LS1 4L60E, so use an LS1 4L60E swap crossmember from someone like Hawks. That will locate the engine/transmission front-to-rear.
I don't believe the 4.3 ever went to the LSx config, but I could be wrong.
Old May 25, 2010 | 05:05 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
4.3 is still 4.3, still in 2010 Silverado 1500s, never went to LSx config., dammit.
www.advanceadapters.com makes some bits for putting a 4.3 into a 2.8 S-10, just use those bits. It'll save you lots and lots of hassles and grief.
Old Jun 1, 2010 | 10:48 PM
Fallen2603's Avatar
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
Hey, just sharing some information I've already gathered. The SBC and the 4.3L 90-degree V6 are almost completely indentical, minus two cylinders and 4.4" of length of the block. I'm still trying to track down mounts that will set the engine back far enough to let the transmission mount in the "stock" position. Both the SBC and the 4.3L V6 have the same bellhousing mounting areas. The bellhousings will swap. So...since the 4L60 and 700R4 are nearly identical, dimensions wise, it should bolt right up. Atilla the Fun and I are going back and forth on this on the "Definitive 4.3 Swap" thread. Apparently, he's done it already...once upon a time.
Oh, here's some Hot Rod articles I've find quite interesting...and INSPIRING. ; )
http://www.hotrod.com/techarticles/e...ild/index.html
http://www.hotrod.com/techarticles/e...all/index.html
Keep me in the loop timmyt649.
Old Jun 2, 2010 | 12:41 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
http://www.summitracing.com/parts/ADD-713119/
Old Aug 24, 2012 | 09:54 PM
williemcfly's Avatar
Car: 1992 Camaro RS
Engine: 3.1L
Bringing this back hey guys I have a 92 25th anniversary RS 3.1 v6 auto that I'm trying to put a 4.3 in. I am a auto mechanic and have access to all the tools, lifts and 3 senior techs with about 65 years of experience between the 3. Some of these parts I will try to make myself or get help locally to keep cost down but for now I need as much input as possible to finally get a documented 4.3 swaped into a third gen.
I was thinking of going with a 94 CPI block (no balance shaft) I would like to run vortec heads tho. Custom grind Delta cam not sure on the intake. I would like to use the intake from the hotels article above but would I be able to use them with the vortecs? Trans? Trans mount? The motor mounts are one of the parts I wanted to make myself to cut cost. Whatever engine I decide on will come with the computer, do I need it or can I use the 3.1's? And what about the harness? Anything else?? Fell free to chime in guys
Old Aug 24, 2012 | 10:05 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Realistically the best way to do the swap would be to use the entire pullout from a newer S10/Blazer.
You could use the 3.1's ecm with some tuning and wiring work, but you'll need a normal port injection manifold for the 4.3.
If you started with a complete setup from something like a 97 S10 for example you'll need:
Swap the transmission tail housing section with the f body housing for the tq arm mount.
V8 engine mounts, you just drill the holes in the correct location on the K member.
Custom Y pipe/exhaust.
Extensive work will be needed to combine both harnesses into one harness using the 4.3's pcm connections and the thirdgens chassis/power connections.
Old Aug 24, 2012 | 10:16 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Fail. I tried this, no go. Starting with a 2.8 or 3.1 car, the easiest mounting is Advance Adapters' part number 713119. And search farther back on 4.3, I already did a full installation with documentation, I just did it to show how, so I never bothered to get it running since I had running V8s sitting around.
Old Aug 24, 2012 | 11:11 PM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
i recommend leaving that car stock though, not a whole lot of those around
Old Aug 24, 2012 | 11:15 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Have you looked at the production numbers on 92 V6 camaros ?
Old Aug 24, 2012 | 11:28 PM
kmcn47's Avatar
Transmission: 5spd
woops all i saw was 25th anniversary heritage and thought it was one of the rare ones
Old Oct 14, 2012 | 08:26 PM
rdmotors's Avatar
Car: 1989 RS with T-Tops
Engine: 2.8L TPI Swapped to LT1
Transmission: 7004r auto Swapped to 4L60E
Axle/Gears: Stock Swapped to 3.27 Posi 9 bolt
I would love to see the progress you have made.
Fast355
Dec 2, 2016 06:33 PM
earlpote
Aug 28, 2015 10:42 AM
E Rod
Aug 28, 2015 05:17 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
jharrison5
Aug 19, 2015 05:53 PM
