283 swap is done
Old May 26, 2010 | 12:21 AM
chefman45887's Avatar
Car: 89 Camaro RS
Engine: 283 SBC
283 swap is done
All done other than body and paint and rims.
http://www.youtube.com/watch?v=KbyxguQ4P-Y
wanted to thank everyone for the support and help with my project
Old May 26, 2010 | 12:33 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: 283 swap is done
Nice clean swap.
What is the idle set at?
Old May 26, 2010 | 12:50 AM
Car: 89 Camaro RS
Engine: 283 SBC
the idle showing on the car is way off tach wise , i have to adjust it a little more im shooting for 1500-1750 rpm. im u tubing how to tune my edelbrock if that doesnt work any input would be cool.
Old May 26, 2010 | 12:59 AM
The recommended RPM at idle for an automatic is 950 rpms'.
I have an edelbrock 600 on my 357 and I can get it to idle around 500, but I also have a manual, and the motor acts like crap when I take off from that low of an idle, so I set it to JUST under 1k and it seems allright.
Just keep fiddling with it, it will eventually go down to where you want it.
Old May 26, 2010 | 01:24 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Is that the first time it was started? Sounds like a cylinder is down on compression when its cranking.
Looks nice, BTW. What are the specs?
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
mustangdmurder
Aug 21, 2015 07:17 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
