454/t56 and AC
Old Jun 4, 2010 | 04:23 PM
  #51
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: 454/t56 and AC
the astro vans used them due to space restraints, also i believe they were valved differently from the trucks. the 2500's had some but much less than the 3500's. as light as our cars are compared to the trucks I'd go towards the astro set the hydraulic valving would be much closer for our cars weight. the trucks used them for slowing down 10,000 lb trailers.
Old Jun 4, 2010 | 05:32 PM
  #52
87bluebird's Avatar
Car: 1987 pontiac firebird
Engine: 6.5 turbo diesel
Transmission: t56
Axle/Gears: Ws6 axle
Re: 454/t56 and AC
would the astro booster work with the truck power steering pump and lines?
Old Jun 5, 2010 | 03:11 AM
  #53
Re: 454/t56 and AC
it should work just make sure you have the pressure lines connected properly, they should be from the pump to the booster to the steering box in that order. if you hook the lines up wrong you wont have the boosted brakes. also the pump should have 2 return lines on it 1 for the booster the other for the steering.
Old Sep 8, 2010 | 12:44 PM
  #54
nathan44's Avatar
Car: trans am
Engine: 5.3 l59 flex
Transmission: 4l60e
Re: 454/t56 and AC
do you have pic of the swap?
Old Sep 21, 2010 | 12:03 AM
  #55
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Re: 454/t56 and AC
Use a flywheel that is for a Mk V one piece rear seal, and external balanced.
