Fuel pump question please help
Old May 29, 2010 | 01:52 PM
GMODUDE's Avatar
Car: 92 Camaro RS
Engine: 5.7L 385 Fastburn
Axle/Gears: 9 Bolt 3.70 Gears
I have swapped my 305 to a 385 fastburn crate engine just recently. My car is now carburated. I took out the original fuel pump and mounted a holley blue pump under my tank behind my rear torsion bar. I have an inline fuel pressure regulator on the car to make sure it is giving the proper pressure. All this was done 6 months ago. yesterday the pump died. I checked if there was power and there was. I checked the ground and took off a fuel line and it was obvious that it wasnt priming the fuel when i turned the key. So my question is. why would this pump died so quick. I mounted it right side up. I have the stock sock filter in the tank still connected so I dont think it would be from trash. I made a heat shield to go over it so no exhaust heat should faze it. What do you guys think. The warranty on Holley stuff is a joke. So idk if it is worth it to try to get another and have it die in 6 months or get a mechanical pump or what. Any help is appreciated. Thank you.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
