396 bbc in 89 iroc questions
Old May 30, 2010 | 08:08 PM
bad_to_the_bone's Avatar
Car: 89 iroc-z
Engine: 427 bbc
Transmission: borg warner t-5
Axle/Gears: 3:23 posi
hey guys just have a couple questions b4 i do my swap just to give myself and idea of what i need for extra work is going to be needed i read the whole swap threads but just want extra comfrot b4 the swap is done
q1 wondering if there is room for tall vavle covers with an a/c heater box or sould be converted to a non a/c unit?
q2 would there be room for the radiator in stock location for a long style water pump and my car came factory with the dual fans?
q3 is there room with the tall valve covers for the wiper motor? (since this is a street car and the area i live in they are mandatory to work)
thanks for your time and info - mike
Old May 30, 2010 | 08:21 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 396 bbc in 89 iroc questions
You can solve 2/3 of those problems by tossing the tall valve covers and whatever is under them that isn't stock height. You really don't need a stud girdle until you're over 800 horses or over 6500 rpm.
i do know the '91-'95 aluminum valve covers will clear the a/c box and the wiper motor if using Moroso solid motor mounts and frame pads.
Old May 30, 2010 | 08:26 PM
Car: 89 iroc-z
Engine: 427 bbc
thanks Atilla the Fun at the present moment there is low profile valve chrome vavle covers on the motor but was planing to put stud girdles and the the tall covers
Old May 30, 2010 | 08:37 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Just use ARP 7/16" studs.
Old May 30, 2010 | 08:40 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
In the thread
92 RS 454 swap,
The Devastator is using a long water pump.
Posts 12 & 13 discuss briefly the pump. Post 19 has a pic with aftermarket pullies.
I don't recall what pump booboosean used.
Good luck & keep us updated!!
Old May 30, 2010 | 08:45 PM
Car: 89 iroc-z
Engine: 427 bbc
thanks guys for your help the motor should be going in once my headers arrives and i can post pics and and curantly installing subframe connectors
PestilenceIV
Aug 20, 2015 02:33 AM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Leggman1
Aug 6, 2015 04:15 AM
