1984 PONTIAC 5.0
Car: 1984 PONTIAC TRANS AM
Engine: 305G HO CA EMISSIONS
Transmission: T5 5 SPEED
Axle/Gears: THEY ARE THERE
1984 PONTIAC 5.0
Hi motorheads,
I have been thinking of upgrading my 305 HO to a new engine. Thinking of a 355 with around 375HP. I think the T5 trans is rated at about 250FPT. Should I rebuild or upgrade to a TKO?? I know that I will need a new clutch, pressure plate and throw out bearing. What about the rear end and axels.
I autocross the car so I don't need more Hp than 375 if even that much.
Let me know your thoughts,
SpokaneTA
SpokaneTA
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: 1984 PONTIAC 5.0
Why not upgrade to a 6spd? A stock t56 drop out can be had for cheaper than a TKO, and they are rated at 450ft lbs. The swap has been done many many times and theres tons of info on how to do it.
That's a great idea. I should be able to find one around this area. Hopefully I can find one and the engine that I am getting reading to purchase has around 425 HP. More than enough for auto cross.
Transmission: 4L80E/4L80E
Make sure it is from a '93-'97 V8 f-body. While you can make other versions work, the years and model listed above would be the easiest to get to work.
I found one in Seattle for 1000.00. I am waiting for a reply on what year ans make it came out of.
The person who has the T56 says that it came out of a late 90's Cadillac. I asked for the numbers on the trans to find out if it is compatable. Probably came out of a CTX or STX Cadillac.
[Sold] Flowmaster exhaust system
Night rider327
Oct 9, 2015 09:25 AM
