MPFI to Carb throttle cable
I also have a v6 mpfi 5-speed car that I bought in the middle of a 350/700-r4 swap(fun stuff
). It appears to have a 650 edelbrock carb (probably from pepboys or the like) and I cant seem to figure out how to get the TV cable hooked up correctly. Im on a bit of a budget so i wouldnt be opposed to making a bracket or something along those lines. I would just like a little more info before i start (ie. where cable hooks to carb, finding proper geometry?, how to adjust cable with homemade bracket).
). It appears to have a 650 edelbrock carb (probably from pepboys or the like) and I cant seem to figure out how to get the TV cable hooked up correctly. Im on a bit of a budget so i wouldnt be opposed to making a bracket or something along those lines. I would just like a little more info before i start (ie. where cable hooks to carb, finding proper geometry?, how to adjust cable with homemade bracket). Joined: Mar 2000
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
I moved this to its own thread, since it really wasn't related to the one where you posted it.
You need to get a cable housing mount bracket, and a TV geometry corrector bracket that attaches to the throttle arm. I wouldn't recommend homemade, especially for the geometry corrector bracket.
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
