VATS disable
Old Jun 27, 2010 | 10:36 PM
Racer#6's Avatar
VATS disable
I have a 1989 camaro 350 tpi and need to disable the VATS . How is that done? i heard there was just a relay you unplug .
Old Jun 27, 2010 | 11:12 PM
kingtoros's Avatar
Re: VATS disable
Hey friend, there's a tech article about it. If you can't figure out the resistance of the key, you can always get a bypass module you can wire in to the ECM that transmits the right pulse at all times. https://www.thirdgen.org/vats
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
Winchester1094
Sep 15, 2015 09:48 AM
