Oil Sender Stand Leak-HEADACHE
Old Jun 30, 2010 | 02:45 PM
bminnix's Avatar
Car: 1987 Trans Am
Engine: Chevy 350 .040 over
I swapped my 305 for a high performance 350 chevy. Everything is smooth except the major oil leak coming from my oil sender unit. I took the necessary measures to make sure the leak wasnt from something else as well...Im positive it is due to the damaged threads on the block for the unit (recently noticed them). I would much prefer not to weld anything and I have tried a bunch of different sealants and an epoxy type weld.
Can I relocate the oil pressure sender to a port near the oil filter and plug the current one?
Any advice?
-Thank you
Old Jun 30, 2010 | 03:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You can, but if the block threads are damaged, how are you going to plug the port you're using?
Old Jul 1, 2010 | 08:14 AM
bminnix's Avatar
Car: 1987 Trans Am
Re: Oil Sender Stand Leak-HEADACHE
Well in that case I may end up welding it, but I wanted to be sure I can relocate without issue before going that route. Are there any kits available specifically for this?
tyeo098
Nov 30, 2015 06:27 PM
eustodp
Sep 20, 2015 05:09 PM
CatmanFS
Sep 19, 2015 09:00 AM
ericjon262
Sep 11, 2015 06:07 PM
Ironhead38
Sep 7, 2015 02:26 PM
