Torque arm help Please
Old Jul 11, 2010 | 07:46 PM
harp_scott's Avatar
Car: 91 RS
Engine: 350 Carb
Transmission: TH-350
Axle/Gears: Stock 3.23
Just swapped 3.1 to SBC350. TH350 in place. Im using a Hurst torque arm adapter. Everything is in place.
My problem. I understand the T/A bracket and it is bolted to the tranny. I have all the pieces from the old 700 drilled out and ready. When I pull the torque arm down to mount to the bracket, it does not fall into place. with all my strength, I cannot pull it over the bracket where it goes. Am I suppose to pry it over maybe? My tranny output shaft is square with the rear end. I will attach a pic.
All help appreciated.
Old Jul 11, 2010 | 08:31 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Re: Torque arm help Please
I had to put my jack stands under the rear frame not the differential and then it went together very easy. It's in a bind while the diff. has a load on it. Good luck.
Mark.
Old Jul 11, 2010 | 08:36 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
First, undo the bracket from the trans. Second, notice how the rear spring perches are behind the centerline of the rear axle. Third, put your jack under the panhard bar bracket, on the driver's side of the axle, and jack up until the front of the torque arm is parallel to the output shaft. Fourth, reinstall the bracket. Fifth, snug everything up. Sixth, release the jack.
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
