84 camaro berlinetta motor mount replacement HELP
Car: Trans Am
Transmission: t5
Axle/Gears: 3:73 borg
My 1984 camaro berlinetta is getting swapped right now for a 350. I had planned to replace the two motor mounts but after I pulled out my 305 I went to take off the bolts holding the motor mount to the sub frame and found I needed to hold the top of the bolt with a ratchet and loosen the nut on the reverse side but it seems that there is no access to the backside with any kind of tool. Since the berlinettas don't have a full frame I believe it is a little different. Would I have to take apart the whole front end to get to something on the bolt??
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 84 camaro berlinetta motor mount replacement HELP
You might consider a search. Members have accomplished the removal with a variety of tools (and cursing). With no springs in the car, removal would be a piece of cake.
JamesC
JamesC
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
There are holes in the sides of the K-member that a ratchet with a joint by the socket end (see below) will fit into IIRC. For other angles, a standard box ended wrench will work better. I don't know of any differences in the Berlinetta frame although some had brackets between some of the components.
Transmission: 4L80E/4L80E
NBrehm
Aug 5, 2015 07:57 PM
