LT1 Acc. setup on 86 engine
Old Jul 23, 2010 | 04:16 PM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
my idea is to use a LT1 accessory setup on my 86 engine I'm building
NOW HOLD ON and read further before you say it can't be done
there are 3 main issue that make the 2 incompatible as I see it
1. need to drill a hole in the head for a 3rd mounting bolt for the main bracket.
2. a keyway needs to be notched into the harmonic balancer to go onto the crankshaft
3. need to use a different front crankshaft seal, which is as easy as putting an LTI seal into the old timing cover
are there any other issue I haven't came across?
Old Jul 25, 2010 | 10:41 PM
C.M.Jones's Avatar
Re: LT1 Acc. setup on 86 engine
no news is good news?
Old Jul 27, 2010 | 08:26 AM
Pocket's Avatar
Car: 91 Trans Am
Any particular reason for doing this?
The SBC stuff isnt exactly hard to find or expensive
Old Jul 27, 2010 | 09:42 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
LT1's don't use a waterpump pully, the belt routing would be almost impossible without another idler pully somewhere, or moving the tensioner, trying to figure that out would not be worth the time iteslf for the reason that Pocket said.
Old Jul 27, 2010 | 10:37 AM
Pocket's Avatar
Car: 91 Trans Am
Maybe he's got an electric WP and wants serp to go around it
Even then a combo of summit brackets would be easier for the essentials like PS pump and alt. Using the LT1 bracket is usually a mix of component delete idlers and a few usable accessories, plus the extended PS lines muck up a clean install
Old Jul 27, 2010 | 11:12 PM
C.M.Jones's Avatar
I plan on using an electric pump and I already have the pulley setup sitting in the shop (freebie)I want it for many reasons
I already have it
its a very simple setup
I am using an electric W/P
its a stock sytem and easy to find replacement parts
Terrell351
Jun 13, 2021 01:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
