fuel pump-do i need one?
Old Jul 24, 2010 | 06:16 PM
lillee64's Avatar
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
i have a 1990 iroc z, do i need the fuel pump on the side of my engine to pump the gas or does it pump from the tank?
Old Jul 24, 2010 | 09:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: fuel pump-do i need one?
your pump is in the tank.
Old Jul 24, 2010 | 09:23 PM
lillee64's Avatar
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
ok good, so that mean i dont need the one on the engine right?
Old Jul 24, 2010 | 10:16 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Correct.
Old Jul 25, 2010 | 12:19 AM
Car: 1992 RS
Engine: Carbed 350
Why are you asking? Are you swapping engines? I'm confused because you don't have one on the side of your block now.
Old Jul 25, 2010 | 12:25 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Do you currently have one on the side of the motor?
Old Jul 25, 2010 | 01:49 AM
lillee64's Avatar
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
no i do not have one on side of the motor. i bought the iroc for $300. perfect condition, just missing a motor. so i did the interior swap, tail light mod, homemade halo headlights, everything. bought a engine and i does not have a fuel pump, i just didnt kno if the car needed one since i never had an engine in the car to look at and tell
Old Jul 26, 2010 | 09:25 AM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
Let me ask you this?
Are you Going Carberator or Fuel injection?
If your going carb you need a fuel pressure regulator to use the fuel pump in tank
If your going Fuel injection your fine with that one
Also what year of motor is yours?
87 and newer(Motor that had no fuel pump on motor from factory) Dont have a spot on camshaft to move the mechanical fuel pump to make it pump
If your going carb I would just get a fuel pressure regulator(you can get new @ jegs for like $25) and a jegs fuel pressure gauge(new for $20ish) and put on your inner fender well depending on carb you run 5-7 psi
I have noticed that my car runs best at 6.5 psi(I use a Holley Red Electric Fuel Pump it was $105)
Old Jul 26, 2010 | 07:45 PM
lillee64's Avatar
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
well im going carb. the engine is from 84 and it does have the spot for a mechanical fuel pump.
Old Jul 26, 2010 | 11:28 PM
Car: 1992 RS
Engine: Carbed 350
If the in-tank fuel pump works, then you can use it, but you need a return-style regulator like the Mallory 4309 - if you pay less than $70 for the regulator, it's not a return-style - they are expensive. But that regulator will reduce your fuel pressure down to a level that the carb can use - your pump makes 40+ psi and a carb only needs 6psi.
Old Jul 27, 2010 | 12:07 AM
lillee64's Avatar
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
whats the difference between a return style regulator and a non return style?
Old Jul 27, 2010 | 07:06 AM
Car: 1992 RS
Engine: Carbed 350
Return style reg regulates the pressure by sending the excess fuel back to the tank.
Non-return style just cuts the fuel off, backing it up in the line.
The in-tank fuel pump is set up as a return style pump - it's made to recirculate the excess fuel - this returning of the fuel keeps the pump running cool and makes the pump last longer. Since the in-tank pump was made to create so much pressure for the fuel injection system that was in the car, running a regular 'dead head' regulator will burn out the pump (because of the restriction). And I'm not sure that a regular regulator would be able to reduce the pressure enough anyway.
Old Jul 27, 2010 | 06:33 PM
lillee64's Avatar
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
so what would be the easiest and cheapest way to do this?
Old Jul 27, 2010 | 08:30 PM
Car: 1992 RS
Engine: Carbed 350
Cheapest would be to drop the tank, assuming your doing your own work. Your labor is free. And unless you know the pump has already been replaced recently (last few years), then it's apt to die at anytime. So I'd drop the tank, and install a pickup, then run an external electric pump or a mechanical pump on the block. Then, you'll never have to drop the tank again.
Old Jul 27, 2010 | 08:33 PM
lillee64's Avatar
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
so drop my tank, take out the electric fuel pump and install a mechanical one on my block?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
