1992 v6fi to 350 carb
Hey everyone i just bought a 1992 v6 FI camaro
When i bought the guy had put a 350 carb in it
just bolted the motor up to the motor mounts.
Ive read to v6 to v8 guide.
I would want to do the fuel pressure with return line
could someone give me a link for a good cheap one ?
the car originally had a 700r4 transmission auto
i have a th350 i am going to put in it
i am on a budget
i read that i need to buy the torque adapter mounting kit
could someone plz post a link to it as well
if there is anything thing else i am missing for the swap plz post
i need to know everything to make it run and drive
your help is appreciated
thanks
o and with the 700r4 shift linkage work with my th350?
i am on a budget
thanks
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 1992 v6fi to 350 carb
1) You need a return-style fuel pressure regulator like the Mallory 4309 - only a return-style regulator will work. They are not cheap, there is no cheap alternative, new they are about $90 - might find one on ebay used that's cheaper, but being used it may need a new diaphram, so might as well bite the bullet and get a new one. Do a search on summitracing.com for Mallory 4309.
2) For the transmission, check the transmission section here and do a search - basically, if you have the right length tailshaft on the TH350 (9 in), then all you need is the tunnel mount for the torque arm as the TH350 never had a torque arm mount on it like the 700R4 does. There is also available a new crossmember that has the torque arm mount on it. If you have the shorter 6in tailshaft TH350, then you will also need a longer driveshaft. There will be alot of info in the transmission section here on the swap, it's done alot. Just type "TH350 swap" into the search box above.
3) Same for the 'linkage' issue - search the threads in the tranny section - there may be a sticky as well at the top of the section. 700R4 uses a shifter cable, I have no idea on the TH350, but I assume it's the same - might need a different cable or something I'm not sure.
Okay well i ordered a mallory 4309
And the tunnel kit you are talking about
does the swap kit from 700r4 to th350 come with everything
ive never done a camaro swap so idk
And does anyone else know about the shifter on th350 difference
cause it does not look like it will mount with it
i will take pictures when i get off work
thanks
thanks
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
