LT1 TB
Old Jul 31, 2010 | 09:11 AM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
LT1 TB
Can someone tell me the differance between the 93 LT1 TB and the 94-97 LT1 TB?
Old Jul 31, 2010 | 12:14 PM
Drac0nic's Avatar
Re: LT1 TB
93 has a stud for a 700R4 94-97 do not. Besides that they use a different kind of throttle cable than a third gen so keep that in mind. The LT1 also uses a different style of IAC/TPS connectors than the L98 throttle body. Just bringing this up in case you're thinking of swapping between em.
Old Aug 1, 2010 | 07:26 AM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
Re: LT1 TB
Ok well I must have a 93 style then. I did get a new IAC/TPS and the new connectors to splice in on the harness. What im not understanding is what style throttle cable to use for my 85 iroc.. should I use the 89-92 throttle cable or will the 93 year work? Also the stock 85 TPI cable measures 34'', maybe a 36'' cable would work well cause the LT1 TB looks like it would use a little longer cable with that style linkage. I cant really mock this up in the car cause the motor is not in yet. Again any help would be great.. Thanks
Old Aug 1, 2010 | 01:43 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LT1 TB
Use either the 90-92 TPI cable or the 93-97 LT1 cable
The 4th gen has a much smaller hole in the firewall so an adapter bracket will have to be fabricated
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
