MORE BBC SWAP PICS-POBOYRACING
Old Aug 4, 2010 | 09:06 AM
bigzeke's Avatar
POSTING MORE PICKS OF MY BUILD , DONT KNOW HOW THIS CAM WILL WORK I HOPE TO HEAR FROM ANYONE WHO HAS USED HERBERT SOLID ROLLERS IN THE PAST
Attached Thumbnails MORE BBC SWAP PICS-POBOYRACING-engine.jpg   MORE BBC SWAP PICS-POBOYRACING-engine3.jpg   MORE BBC SWAP PICS-POBOYRACING-engine4.jpg
Old Aug 5, 2010 | 12:40 AM
NAASBC355's Avatar
Car: several
Engine: Lots of them
Transmission: also lots of them
Axle/Gears: lots of them
Re: MORE BBC SWAP PICS-POBOYRACING
Camshafts have several eccentric lobes which use rotational motion to create a vertical motion thus "lifting" the lifters off the "base circle" of the cam up the ascending side of the lobe over the nose back down the decending side of the lobe finaly coming to a peacefull rest back on the base circle of the eccintric lobe so i'd imagine it will lift the lifters spec's would help...
~Couch
P.S. I know I know YOU Me
Old Aug 5, 2010 | 02:05 PM
bigzeke's Avatar
no ****, i didnt ask for a definition ,only if you had ever used their products before specs ill keep to myself . bigzeke--------------POBOYRACING
Old Aug 5, 2010 | 02:08 PM
bigzeke's Avatar
IF ANYONE HAS EVER USED CHET HERBERT ROLLERS BEFORE I WOULD JUST LIKE TO KNOW HOW IT PERFORMED FOR YOU .THANKS IF YOU CAN HELP BIGZEKE---------------POBOYRACING
Old Aug 5, 2010 | 03:12 PM
bigzeke's Avatar
you mispelled ascending and eccentric doctor!
Old Aug 5, 2010 | 05:16 PM
NAASBC355's Avatar
Car: several
You said you didn't know how it was going to work . Seriously though cam cores are pretty much all made by a handfull of people so material quality is all relativly the same it's just how accurate did they grind it in relation to from lobe to lobe, and timing in relation to the dowel pin. Last I looked there are only like 5-6 lifter manufacturers making lifters on a full scale basis as in not just making top fuel lifters for example. So chances are you have a set of GM, Eaton, Isky, Johnson, or Stanadyne lifters once again quality is all roughly the same. Johnsons being the most famous has sprung back out of bankrupcy under topline's colors Delphi is making GM's lifters (top notch) isky goes without intro as a clear valve train leader, Eaton is run of the mill type stuff, never seen a set of Stanadyne don't even know if they are in business, and finally Morell (sp?) they make premium racing lifters including top fuel lifters, but are elusive at best. I have seen two sets of those in my life one of which is going in my trailor queens next motor
~Couch
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
sreZ28
Aug 14, 2015 07:48 PM
