My Proposed 383 Build.
Old Aug 8, 2010 | 08:59 PM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Trying to Figure what i'm gonna build as my 383. Here are the parts i'm considering. you guys gotta keep me from making a mistake.
Bottom End:
http://cgi.ebay.com/ebaymotors/Sbc-E...#ht_1232wt_939
http://cgi.ebay.com/ebaymotors/HOWAR...#ht_4992wt_936
http://www.summitracing.com/parts/CCA-12-443-8/
Heads:
http://cgi.ebay.com/ebaymotors/SBC-C...t_12200wt_1165
Old Aug 12, 2010 | 11:08 PM
unionfootball06's Avatar
Car: 1989 Camaro RS
Engine: 388 C.I. forged stroker motor
Re: My Proposed 383 Build.
the eagle set looks good.... i used scat and i prefer king bearings but thatll work... i used the same cam but i bought the full set of lifters AND cam from comp... the heads arnt bad but if i were you id shoot for some 74ish cc combustion chambers or else your compression is gonna be high... i assume you wanna run pump gas?
you have a great set up! be sure to check rod to wall clearance before your final assembly... i know youre gonna have to grind it off... a dremel works well
Old Aug 12, 2010 | 11:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You'd better talk to Skip before you order. The cam has more lift than he says the heads will handle.
Old Aug 13, 2010 | 01:05 AM
Car: 1989 Camaro RS
here are the heads i ran with that same cam:
They are cast iron and have 235cc intake runners and 72cc combustion chambers with angle plugs. 2.08/1.6 stainless steel valves, single 1.25inch valve springs that can handle a .600 valve lift. they flowed :
INT / EX
.1-73 / 61
.2-145.1 / 115.3
.3-204.4 / 149.8
.4-250.9 / 170.6
.5-286.1 / 189.6
.6-305 / 198.1
.7-311.1 / 201.8
.8-313 / 203.6
the brand was engine quest
Old Aug 13, 2010 | 09:11 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
With that cam having such a late intake closing. there's no problem with running 11:1 on pump premium.
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
