How to clean heads!
Old Aug 10, 2010 | 12:24 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
How to clean heads!
So im about to put my vortec heads back on and i want them to give them a good cleaning but i dont got money to take them to the shop so my question is can i just scrub them with like water or gas to clean them up like the inside of the heads and stuff any help is greatly appreciated thanks!
Old Aug 10, 2010 | 12:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: How to clean heads!
Try oven cleaner.
Old Aug 10, 2010 | 12:30 PM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
brake cleaner works good i believe, and some scotch bright... I definately wouldn't use water. It will take some time to get good. A hot tank bath and safety clean machine is ideal.
Old Aug 10, 2010 | 01:50 PM
Engine: 350 tpi
so i should just spray it with brake cleaner and let it sit...can i use gas?
Old Aug 10, 2010 | 03:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If they are assembled, you should avoid solvents that could damage the valve stem seals.
I just took a pair to the self-service car wash and used their wand. Came out pretty decent - although I was mostly trying to wash the oil off them, some of the carbon came off the chambers as well (I didn't concentrate on the chambers).
Old Aug 10, 2010 | 03:38 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
One of these
http://www.greatnecksaw.com/product_...ped-wire-brush
and a good drill cleaned the chambers/valves up nice on my old L98 heads. Works on the outside also.
Old Aug 10, 2010 | 03:43 PM
Engine: 350 tpi
cool they dont look bad but just wanna get them clean. Theres no build up or anything.
Bubbajones_ya
Aug 28, 2015 02:17 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
mdtoren
Aug 23, 2015 12:52 PM
qz6lwp
Aug 20, 2015 08:10 PM
mdtoren
Aug 16, 2015 05:45 PM
