NEED SOME ADVICE!! PLEASE
Old Sep 5, 2010 | 05:17 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
Whats up guys? Well hopefully tomorrow i will be dropping my new motor in i just needed some help...what is the easiest way to get it in?? The transmission is still in the car thats why im asking..any help would be great thanks.
Old Sep 5, 2010 | 08:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: NEED SOME ADVICE!! PLEASE
There is no easy way, you just have to do it.
Old Sep 5, 2010 | 08:24 PM
Maeryk's Avatar
Car: 89 Formula 350
Engine: 355 long block TPI
Transmission: auto
Axle/Gears: Richmond 4:10 Eaton Posi
slow and easy, don't rush the process. Line up the tabs/holes on the bellhousing, and work methodically. make sure you hook up the groundwire.. I watched an emergency brake line get bright red and droop when they forgot to do so in a Ford engine swap I was idly watching.
Old Sep 6, 2010 | 11:30 AM
Engine: 350 tpi
ha ha well i dont even have my wiring in yet im just putting the motor in to clear up my garage...hopefully it goes will
Old Sep 6, 2010 | 04:31 PM
Engine: 350 tpi
Well attempt number 1 fail!!! i could not get the torque converter to go into the shaft..and transmission fluid was all over the place so i called it quits...should i just pull the transmission out?
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
