305 to 327 tpi
Old Sep 18, 2010 | 08:34 PM
joegugino's Avatar
Car: Iroc
Engine: 6.2l LS3
Transmission: 4L65E
Axle/Gears: 10 bolt 3.42
305 to 327 tpi
the 327 is 40. over bore with 10 to 1 compression flat head pistions. i dont know what head to buy i think edelbrock vortech ,chevy fastburn or brodix head. i planning on getting a edelbrock manifold of the heads. i dont know what size injectior i should get?
Old Sep 19, 2010 | 07:25 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 305 to 327 tpi
you're proposing a serious mis-match. If you're commited to keeping the long-runner TPI, then save or sell the 327 crank, and go for the cubes of a 350 instead. If you're committed to the 327, then save or sell the TPI, and get an HSR.
Either way, forget the GMPP Fast-Burn heads, they're crap. 40 cc larger intake ports than iron production truck Vortec heads, 0.060" larger intake valves, too, but even so, they still can't out-flow the truck heads. That points out a severe loss of port volume, which is what TPI is based on.
For the same money as a FB-headed TPI 327, you'd be much happier with the results of a Vortec 383.
Just because you have the 327 is not good reason to install it into these cars. Find a Miata to swap it into. That'd be way more fun, anyway.
Old Sep 20, 2010 | 11:23 AM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Re: 305 to 327 tpi
10 to 1 compression with what cc heads and gasket? For the heads, you need to stick to as close to 58cc as possible like the 305 torquers and use Felpro 1003 gaskets.
Old Sep 20, 2010 | 07:18 PM
joegugino's Avatar
Car: Iroc
Engine: 6.2l LS3
Transmission: 4L65E
Re: 305 to 327 tpi
i talk to the machine shop they said a 68 cc head will work good for the set up.
Orr89RocZ
Apr 25, 2016 08:28 AM
masonta
Aug 31, 2015 10:14 PM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
