think i know answer just need confirmation
Old Sep 26, 2010 | 07:18 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
97 tahoe 5.7l. Can i reuse the serpentine brackets in my firebird or is there no room. 3 inch cowl hood though i dont think thats gonna help with the alternator and PS. Also going to use the poly motor mounts, i dont want to run into any problems with dyno dons headers, so unfortunatly theres more height that could hurt
Old Sep 26, 2010 | 09:18 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: think i know answer just need confirmation
the ac compressor on those trucks sit pretty high. i think it will hit the hood.
Old Sep 26, 2010 | 03:42 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
going with a ac delete box and pully, so you think thats the only concern? i should be ok?
Old Sep 26, 2010 | 04:53 PM
i cant say for sure. im running that setup on my S10 and its a close fit. have you taken measurements?
Old Sep 26, 2010 | 07:52 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
never measured with it assembled, Unfortunately my car is 230 miles away from me, Am going up there in 2 weeks too assemble the motor and drop it in. Problem is ill be delayed if it doesnt work and then need to find new brackets lol Or i can buy a set now, wanted to save the $200 if someone had an answer, figured trying wouldnt hurt
Old Oct 1, 2010 | 06:48 PM
Pocket's Avatar
Car: 91 Trans Am
Use car serp brackets
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
