TPI to Carb, What Distributor
Old Sep 28, 2010 | 07:26 PM
Matemk's Avatar
I am pulling the motor out of my 90 Camaro Iroc, 350 TPI, and putting it into my 79 El Camino. I am going to remove the TPI system and put on a 2104 Edelbrock Intake and 1406 Edelbrock Carburetor. Leaving the rest of the motor alone.
My question is what distributor do i need to use?
Old Sep 29, 2010 | 12:17 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Do you have the '79 distributor? If so, it will be fine. If not, something like it.
Old Sep 29, 2010 | 10:13 AM
chesterfield's Avatar
Car: Pontiac
Re: TPI to Carb, What Distributor
would he need a bronze (or melonized) distributor gear with that?
Old Sep 29, 2010 | 10:26 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not with a stock cam
Old Sep 29, 2010 | 11:10 AM
Car: Pontiac
according to Sallee-Chevrolet:
"2) All Roller camshafts are either Hardened Iron core or Steel camshafts which require a hardened distributor gear."
Wouldn't that include the cam from a stock 1990 l98?
Old Sep 29, 2010 | 03:09 PM
five7kid's Avatar
Not bronze. Melonized.
I don't recall if the small-cap distributors used the same shaft size, but if they did, the gear off of the later distributor would be fine on an earlier large-cap. Or, you can get the melonized gear from GM.
Old Sep 29, 2010 | 05:38 PM
Matemk's Avatar
Would it be easier instead of trying to buy a new gear, just taking the stock distributor out and taking the gear off of it, then buying an Accel 59107 GM Hei Distributor and putting the stock gear onto that?
Old Sep 29, 2010 | 06:09 PM
five7kid's Avatar
If the shafts are the same diameter, you can do that. But, I don't know whether or not they are.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Jan 29, 2017 07:00 PM
86IROC112
Aug 17, 2015 02:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
Sanjay
Aug 12, 2015 03:41 PM
