this sound is driving me NUTS
Old Sep 29, 2010 | 10:43 AM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
I have a TPI 305 in my car, it was a 305 TBI when it was in my old 88, it ran well, no strange sounds, good engine, but slow.
I pulled it, swapped it over to tuned port, put an LT1 cam in it, and originally had 19 lb injectors. I set the valves, then set the timing to 9*. car ran pretty quick, but whenever I got on it, there would be this rattling sound from the motor, I thought valves and readjusted, nothing, I thought maybe pre-ignition, but timing changes do not make any difference, nor does high octane fuel. it's definately not a rod knock, my knock sensor is not showing knock.when I lug the engine in 5th gear, the farther I push the gas the louder the rattle like sound gets. i put in 24# lt1 injectors, the noise is still there, unchanged, it has never gotten better, or worse, its only under load, i never hear it at idle. opinions?
Old Sep 29, 2010 | 06:28 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: this sound is driving me NUTS
Clutch throwout bearing? If you step on the clutch, does the noise go away? My LT1 has a pretty noisy throwout bearing that I have to get around to fixing sooner or later, and its really only audible at low rpm, but its definitely a rattle almost like spark knock.
Old Sep 30, 2010 | 09:25 AM
Chevy8588's Avatar
definately not, before i swapped from auto to manual, it still made that noise
Old Oct 1, 2010 | 02:03 PM
Chevy8588's Avatar
bump for peace of mind?
Old Oct 1, 2010 | 02:11 PM
zachkuby87's Avatar
Car: 1985 iroc z
Engine: 350 .30 over
Transmission: t-5
Axle/Gears: told aftermarket moser 3.73 posi?
I had a similar problem in my 84 monte carlo it ended up being the flywheel and starter were jacked up I swapped em both out and sound went away
Old Oct 1, 2010 | 02:50 PM
Chevy8588's Avatar
the car got a new flywheel and starter with the T5 swap. noise still prevelant
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Omega
Oct 1, 2015 02:20 PM
gta90
Sep 15, 2015 04:00 PM
gta power
Aug 13, 2015 06:15 AM
mustangman65_79
Aug 8, 2015 12:07 PM
