What is the best path?
Subscribe
Sep 30, 2010 | 06:30 PM
I am looking at a complete engine build project with a goal of around 400hp. I have potentially two different starting points: a LT1 out of a '93 Camaro or a 4-bolt 350 out of a late 70's pickup thats not been modded. The old 350 has been sitting outside for 2 years and had water inside the heads. It was ran in a rock crawler before it was taken out. I can get it given to me for free or the LT1 for minimal money. The LT1 had been smoking some before being taken out. If I go with the LT1, I would be thinking of converting to a carb. I don't know if I would ever put it in my '84 T/A or not, but I want to build one right taking my time as money comes available. What would be my better path to choose?
Reply 0
Sep 30, 2010 | 07:04 PM
Re: What is the best path?
is the 350 froze up? or does it turn over? And what do you have to spend to get the LT1?
Reply 0
Sep 30, 2010 | 10:30 PM
Sounds like either would need at least a basic rebuild. Of the two, I'd go for the LT1. Stronger bottom end, better heads, better intake, already has a roller cam setup, and the EFI system is excellent on those.
Reply 0
Oct 2, 2010 | 09:17 PM
93 Lt1s are kind of lame though, kind of like the 98 LS1s
Ugly ducklings
Reply 0
Oct 3, 2010 | 05:56 AM
'93 aren't really all that different than any other year... my '97 isn't much different aside from the vented optispark. '93 is an easier year to swap into a 3rdgen though, as its got a similar fuel system hookup to the TPI cars (if I remember right) unlike the later years that used the plastic fuel lines. Its also got a TB that works with a regular 4L60... doesn't have to be the 4L60E.
And its still going to make 275hp, unlike the wimp from the '70s that *might* make 180hp.
Reply 0
Oct 3, 2010 | 10:02 AM
Wierd intake, wierd shaped fuel rails, terrible ECM (not even a PCM yet), old style opti, old style everything really
Fuel hookups are the same for all LTx engines, all were quick connects. Dr/pass side changed from vette to others
ECM is similar to the old 90-92 SD TPI's, but compared to the newer LTx PCMs its a Nintendo box vs PS2
It got the 4L60 as did all Fbodys after 89. The ECM flat out couldnt control the E class trans until 94 when it changed to a PCM
Reply 0
Oct 4, 2010 | 09:52 PM
What about converting the LT1 to a carb motor? That may be what I would be looking at doing if I were to put it in my Trans Am, I dont want to fool with any of the computer additions in this car. Would the LT1 be a better path as a carb motor?
Reply 0
Oct 5, 2010 | 01:40 AM
Ok so convert the LT1 to a '94/95 PCM. Its not hard or expensive. LT1 is still the better choice.
Reply 0
Subscribe
