just did tbi to tpi swap now no spark or injector pulse
Old Oct 2, 2010 | 10:03 PM
masteller's Avatar
Car: 1991 RS
Engine: 355 TPI
Transmission: t-5
Hey I just finished or thought I finished the 305 TBI to 350 TPI SD swap in my 91 RS but now I cant get any spark at the coil and Im pretty sure the injectors arent firing. The fuel pump comes on when i turn the key on but the engine just cranks and wont start. The pump runs for about 2 seconds after i stop cranking and there is 12 volt to the coil through the pink wire. Ive been thinkin its the ICM but I wanted to see what everyone else thought.
Old Oct 2, 2010 | 11:26 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: just did tbi to tpi swap now no spark or injector pulse
Some more info on what parts you used ( ECM / wiring / etc ) and how you did things might help diagnose the problems
Old Oct 3, 2010 | 12:01 AM
masteller's Avatar
Car: 1991 RS
Engine: 355 TPI
Transmission: t-5
I used the 730 ecm and just repinned my tbi harness for the speed density. Ive gone over the repinning procedure 3 times and checked all the plugs and sensors. The ecm is working i believe it only shows code 12 as the only code stored. Have plenty of fuel pressure. Its the original dizzy out of my 305.
Old Oct 6, 2010 | 07:39 PM
71ChevelleSS's Avatar
ignition module or your coil is bad but can you smell gas when cranking? Have you checked all your fuses?
Old Oct 9, 2010 | 09:23 PM
ATOMIC's Avatar
Car: 88 gta (black/black wheels)
Engine: 350tpi
Transmission: 700r
Axle/Gears: 3.27 posi
do you still have the v.a.t.s. system wired up or did you bypass it in the ecm programming?
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
