2.8 to 4.3 swap?
Old Sep 28, 2010 | 08:38 PM
Krispie7377's Avatar
2.8 to 4.3 swap?
Hello,
My son has a 1988 camaro with a 2.8 engine, not sure of the transmission. We also have a 4.3 out of a chevy s-10 blazer 4x4. Can the engines be swapped? What else needs to be changed if anything? I appreciate any help!
Old Sep 29, 2010 | 10:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
The 4.3 has unique front engine mounts to any of the engines the factory put in 3rd gens. Some members have done it, but there will be fabrication involved.
The 4.3 uses the V8 bellhousing pattern, which isn't the same as the 2.8l. The 4x4 transmission would need a different output shaft housing, and output shaft (which requires complete disassembly of the transmission) to work in the 3rd gen.
Old Oct 9, 2010 | 11:51 PM
ATOMIC's Avatar
Car: 88 gta (black/black wheels)
Engine: 350tpi
Transmission: 700r
Axle/Gears: 3.27 posi
Re: 2.8 to 4.3 swap?
is the 2.8 tbi or mpfi? is the 4.3 tbi or vortec?
the easiest way with the trans is to sell it and get one from an f-body, caprice or 2wd truck (s series or full size). that will far cheaper than having the output shaft changed.
most places charge more than half the cost of rebuild to swap the shaft. its the same labor for them.
Cleotiz
Jan 6, 2018 08:56 PM
Digs_do_it89
Aug 30, 2015 10:24 AM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
86Base
Aug 8, 2015 01:34 PM
