AFR 190cc old casting spring swap
Old Oct 3, 2010 | 07:18 PM
2bfeard's Avatar
Car: 1986 iroc
Engine: 350 .060 AFR HSR XFI280
Transmission: transgo 700r4
I have the old casting AFR's 190's running on my car with the XFI280 cam. I'm not sure what springs these heads have but am pretty sure they're the original weak springs they came with. So, I want to swap out this springs for better ones but I don't know where to start, there's so many sizes and different specs!
Would the AFR 8019 springs fit? I want something close to those springs but am not sure if this spring will bolt on straight to my heads?
Also, I was considering in getting that AFR Rev Kit and keep the same springs, would that help me or should I just go ahead and get better springs, reason for better springs or rev kit is I think am floating valves above 5800, I been shifting 6200.
please help!! it's my first engine build.
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
