Engine Swap Help/Suggestions
I have a 1986 Pontiac Firebird currently with a 350. I was wondering if it is possible to swap the 350 to put in a Nissan Skyline RB26DETT engine. Or if anyone has any suggestions of if I should swap the engine or build it up. Any help or ideas would be appreciated.
Car: 1988 rs
Engine: 555BBC; Dart, Lunati, SRP, Howards
Transmission: ATI TH-400
Axle/Gears: 35 spline 9", locker, 3.00's
Re: Engine Swap Help/Suggestions
if you want to attempt to swap in the skyline engine, everything will need to be custom fabbed. just build the 350 up, or if your budget is that high, build a dart block 427-434 sbc. way better than the skyline engine.
American engines go in American cars, not import engines
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It'd be a whole lot of work just to make less power than you can get with bolt-on parts on an SBC that already fits the car.
Exotic engine swaps are almost always "if you have to ask..."
theshackle
Mar 5, 2017 06:37 PM
