1989 350 TPI SHORT BLOCK HELP
Old Oct 16, 2010 | 06:23 PM
PHOENIX FORMULA's Avatar
IAM NEW TO TPI STUFF
I NEED SOME HELP WILL THIS GM SHORT BLOCK WORK
1. I WANT TO REUSE MY HEADS AND STOCK TPI http://www.summitracing.com/parts/NAL-12556121/
2 OR USE GM LONG BLOCK ( KEEP THE HEADS FOR ANOTHER PROJECT ) REUSE STOCK TPI & HEADS
( DON'T WANT TO GET A NEW MANIFOLD BUT I AM GETTING NEW CAM )
3. RECOMMEND A ROLLER CAM REPLACEMENT OR LITTLE OVER STOCK IS OK
4. I JUST RATHER GET NEW GM MOTOR THAN REBUILD OLD ONE
PRICE ABOUT $1800.00 PLUS TAX NEW SHORT BLOCK ,CAM ,WATER PUMP,TIMING CHAIN,GASKETS,
THAT'S CLOSE TO MY BUDGET OF $2400
THANKS YOU FOR YOUR HELP EVERY ONE
I WANT TO KEEP THIS STOCK AS POSSIBLE DRIVEN IN GOOD WHEATEAR ONLY
1989 WS6 350 TPI FORMULA FULLY LOADED NO T-TOP's
Old Oct 17, 2010 | 06:44 PM
Re: 1989 350 TPI SHORT BLOCK HELP
Help: just me posting again GM crate motor 12530283 For 1996-2002 Chevy/Gmc trucks 350 with Roller camshaft will this motor work with my L98 heads and tpi I could use all the accessories from my old motor
Old Oct 17, 2010 | 08:48 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Since you are only changing the shortblock, yes it will work fine. However just be ready to compensate as those pistons may raise your compression ratio a bit. But I cant give an exact number based on summits description.
Old Oct 17, 2010 | 09:02 PM
PACE Performance #12556121 SPEC's ARE
SAME Shortblock Used With #12568758 & #12520270
(1987-1995 Truck Engine) & 1996-2000 Chevy & GMC Vortec 350 (Vin Code R)
When used with 76cc heads compression ratio will be 8.1:1
When used with 64cc heads compression ratio will be 9.1:1
When used with 62cc heads compression ratio will be 9.2:1
When used with 58cc heads compression ratio will be 9.6:1
anesthes
Mar 10, 2016 10:35 PM
camaro71633
Sep 1, 2015 10:24 AM
lakeffect2
Aug 23, 2015 08:44 AM
bamaboy0323
Aug 15, 2015 07:20 AM
BBSDesigns
Aug 11, 2015 07:39 PM
