help quick please
Old Oct 21, 2010 | 08:31 PM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
help quick please
Hey guys i recently got screwed on a 350 tpi deal but besides the point i have a 305 tpi 87 camaro i found a 1989 Chevy 350 motor out of a 2500 pickup for sale it is a fuel injected motor. can i put my tpi intake on the 350 motor from my 305 even though its 305 and 350 and the 350 was not tpi but just fuel injected? also i dont know if the computer was ever changed when the kid removed the 350 form my car and put in the 305 but if he did do i need to change the computer? any advice on this swap would be helpful
Old Oct 22, 2010 | 12:30 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: help quick please
Your TPI will go on the 350 shortblock, no problem. Expect to change the knock sensor, maybe the injectors, and do some computer work to get it running optimally.
Old Oct 23, 2010 | 10:48 AM
any suggestions on if I should do a rebuild before putting the motor in the car? the guy says it ran fine but thinking about it. the motor is 20 years old i think its worth doing a rebuild but suggestions would be nice
Old Oct 23, 2010 | 11:46 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Opening it up and inspecting it wouldn't be a bad idea as long as it's already out of the car. If everything measures ok, you could just hone it and put it together with a new set of rings and bearings. If it needs something more than that, then the time to find out about it is now.
Old Oct 23, 2010 | 02:26 PM
how should i go about finding out if the injectors in my car are for a 350 motor or 305? since i don't know if things were actually changed or not.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
