mystery 355
Car: 1988 Pontiac trans am
mystery 355
im in the process of purchasing a 355 shortblock with hyper pistons ,i plan on building a N/A carb motor, anyways the owner says its from a first ne f-body , i want to throw a roller cam in there " like in most 3d gen cars "
how do i know is its roller cam friendly ?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: mystery 355
If its the old style block, you can get a retro fit roller setup, but its not cheap. The newer blocks can use factory roller parts and those are relatively cheap. Whats the casting number on the block?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: mystery 355
no casting numbers yet im waiting on the guy to send me the numbers.
Re: mystery 355
this is the block , http://www.ls1tech.com/forums/wester...ock-150-a.html BTW what are the pro's nd cons of tappet lifters vs. roller lifters anyone ?
Re: mystery 355
Not a roller motor.
That's a "010" casting; could be the single most common 70s casting of them all.
As said, you can get the original roller system for it, what is now known as the "retrofit" style since the factory came out with their own bizarre thing. The advantage to rollers is that they allow for a MUCH more aggressive ramp opening and higher lift without destroying things. Therefore any GOOD roller cam (not a stock one) will give more power for the same level of "big cam" hassle.
Re: mystery 355
Not necessarily; just, it's just yerbasic old motor, nothing special, and will cost ALOT of $$$, relatively speaking, to make into a roller setup.
$140 is probably about right.
But if you DEFINITELY want to go roller, it's probably not the right one FOR YOU. Keep your eyes open for a working 96-99 350 short block out of a truck or van, instead.
codeysabatini
Nov 10, 2015 04:07 PM
darwinprice
17
Oct 11, 2015 11:51 PM
