406 hsr build
Old Oct 30, 2010 | 11:48 AM
faster1k's Avatar
Car: 89GTA, 62' GSXR1000-SS
Engine: 406-HSR
Transmission: Nocturnal
406 hsr build
Im almost finished with the motor and looking for any tips or help and expectations for what i have coming together..
88 GTA
76 SBC 400 .030 over
11:1 flat tops
Procomp 210cc Aluminum Heads
292xfi cam hydraulic tappet
1.5 roller rockers
HSR setup adj. fpr
700r4 w/ 2200-2800 stall w/3.42 gear
Full long tubes. (Y into single, or duals with X?)
Any help while keeping it cheap. i have access to a dyno and i do motorcycle tuning so i understand it all but what tuners are you using for low budget. And any ideas on expectations? Im shooting for low 12s and 450 to the crank
Old Nov 5, 2010 | 10:56 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 406 hsr build
sounds like a good setup in the works
as for tuning, you're best bet would be to take a look here:
https://www.thirdgen.org/forums/diy-...ns-needed.html
Old Nov 9, 2010 | 09:29 AM
faster1k's Avatar
Engine: 406-HSR
Re: 406 hsr build
thanks, do you know of any way to retrofit the stock tpi on the 406 with old style 210cc heads..
Old Nov 9, 2010 | 09:57 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 406 hsr build
You talking about the bolt pattern for the 4 center bolts at the 72 deg angle? You can oval out the holes to bolt the manifold down to the heads...or you could possibly get a 85-86 TPI manifold which didnt have the altered angle bolt holes.
Also the vette TPI manifolds I think did not have the altered bolt holes but I could be wrong...
Will the manifold fit on those heads?? Arent those 1206 port intake runners and stock TPI is only like 1204 and cant really be opened up much. I think you may have sealing problems
Jorlain
Oct 8, 2015 01:57 AM
86z89iroc
Oct 5, 2015 01:04 PM
86CamaroDan
Sep 29, 2015 10:08 PM
BBSDesigns
Sep 22, 2015 03:08 PM
355tpipickup
Sep 4, 2015 05:32 PM
