Help on a Pontiac 455 into '88 GTA
Old Nov 2, 2010 | 09:44 PM
Bistrof250's Avatar
So I am putting a '71 Pontiac 455 out of a firebird trans am into my GTA and I am asking my fellow members to help me out to give advice about it. Like the headers issue and the wiring considering (mine came with a 350 tpi) with digital gauges and the whole GTA option package like the system check on middle dash and other cool stuff... The transmission mounts and engine mounts. I baught the engine from a local builder who built it up with about 450 horse I am only 17 and will not be able to work on it 24/7 cause of school but plan to go into the engine rebuilding and auto mechanics career.
Old Nov 2, 2010 | 11:08 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: Help on a Pontiac 455 into '88 GTA
Did you read through this? https://www.thirdgen.org/forums/engi...-v8-swaps.html
Old Nov 3, 2010 | 05:39 PM
MaxpowerTA's Avatar
Car: 1992 T/A convertible
Engine: LB9 TFS175heads Ebase/accel runners
Transmission: T5 5spd
Axle/Gears: 4.11
fyi the 455 didn't come out till 1970, And didn't go into a trans am until 1971
Old Nov 3, 2010 | 05:46 PM
Bistrof250's Avatar
My bad, I Dont know exact specs on engine but I can get them
Old Nov 4, 2010 | 02:25 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
This is a uh...hefty project to tackle. Is this your first swap?
Old Nov 4, 2010 | 04:01 PM
Bistrof250's Avatar
Yes! Lol but I have many years to complete it I want it done by 2012 power tour, cause it's in Wisconsin! Lol but I have lots of help from you guys and my stepfather and the guy who actualy built the engine. So I think I can finish it... Lol
Old Nov 5, 2010 | 04:05 PM
Bistrof250's Avatar
went and looked at engine today cant tell much more then what was said
Old Nov 5, 2010 | 09:48 PM
Rtyauch301's Avatar
what head # is on just wondering i want to get an idea of your c.r. you my have to run premium gas(alot of those old pontiac engines before 74 had 10.5-11:1 c.r.'s) .... it should be a big # cast into the top of the exhaust port on the drivers side of the engine.. the size if its a 455 should be cast into the block at the top were the tranny bolts up. it could still be a 455 and and be older then 70 as pontiac used the same block on all their V8's so all most of the small v8"s can be bored and stroked to any of their displacements...
Old Jan 10, 2011 | 04:43 PM
howesbird's Avatar
Car: 1988 Pontiac Firebird
Engine: Pontiac 400
Transmission: 4L80e
Good luck man its not too bad to do. The only problem is exhaust. You can run manifolds and have a exhaust shop bend u a y pipe (what I did). Or u can try and find headers that will fit lol supposably 2nd gen headers fit
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
