My swap problem that I must fix!
Old Jan 9, 2011 | 06:32 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
I swapped a tpi setup in my car, that was originally a PFI v6. Now the car is an 88 firebird, and all underdash wiring right up to the dash side c207 is all for an 88 2.8 PFI v6 .
From the c100 engine bay side to the ecm side is all an engine harness from an 87 tpi camaro swap. Now, I had to change many pinouts on the c100 connector, and had trouble with injector power, but that was found and fixed.
Ive driven the car for several months, and havent had much problems. My main problem is with KOEO, the fuel pump stays running, I know this is related to the v6 swap. Anyone else run into this? My guess is a 2.8 pfi and TPI wiring issue
ANYONE's input is appreciated!
Old Jan 9, 2011 | 09:19 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: My swap problem that I must fix!
Your pump won't shut off? Why not wire it to a switch...
Old Jan 9, 2011 | 10:12 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
sounds like a simple fix to me.. and then u have a kill switch at the same time.. dont have to worry about someone stealing ur car just hide the switch in a reach-able yet hidden area
Old Jan 10, 2011 | 09:09 AM
Pocket's Avatar
Car: 91 Trans Am
http://www.austinthirdgen.org/mkport...ine_wiring.gif
87-88 are pretty similar even V6 to V8. The fuel circuit isnt that much of a change. Running constantly sounds like you've got the ECM wire hooked to battery 12v
Old Jan 10, 2011 | 09:34 PM
Its only KOEO. I think i found on mitchell that 88 firebird 2.8 uses D on c207 to power the cooling fan, and uses g4 on c100 for Fuel pump feed from relay, while 87 camaro use d 0n c207 for fuel pump feed.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
