Trying to ID my engine
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
As the title states I'm trying to ID my motor. I was told by the previous owner that he installed a crate 350 due to the original motor being blown. I have searched the entire front of the block and cant find any castings. Only thing I could find was tag with the following information:
CLV-1
68188
I've searched google and cant find any relation to these numbers. Any other suggestions on identifying what kind of motor it is?
CLV-1
68188
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Trying to ID my engine
Best it is going to give you is engine ci
Any codes on the front block pad will be meaningless if engine rebuilt ( unless GM crate engine )
Re-builders usually stamp their own ID codes for warranty purposes
I dont have that lip on mine by the valve covers like you show in your picture. Everywhere I've searched says to look there.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes you do. It's not near the valve cover, it's behind the head at the back of the block.
Car: 82 Z28
Transmission: T400
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
also dont forget, every PO has installed a 350 in the 3rd gen your about to buy, infact, its possible there isnt a single 3rd gen for sale with a 305 in it!
84z96L31vortec
Aug 20, 2017 12:16 AM
