Can anyone identify this engine & heads?
Old Nov 12, 2010 | 08:45 PM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
Alright so im going to purchase this "350" engine with "vortec" heads.
I was wondering if anyone can confirm that this is indeed a 350, and that the heads are indeed vortec?
I just want to double check before i decide on buying.
I took pictures of almost every number i found on the block and heads.
I also took pictures of the pistons and was wondering if anyone has used them before/had experiences with that brand?
Any info on these would be great.
Heads
Block
Pistons
Old Nov 12, 2010 | 08:48 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Can anyone identify this engine & heads?
906 - Vortec head
062 - Vortec head
880 - Roller cam 350ci block
Old Nov 12, 2010 | 09:06 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
the vortec head is not a brand,its a gm factory part,one of the better designs,but will require you to get a different intake manifold to match the bolt pattern on the heads.you wont be able to use all the older non vortec intakes.there is no egr passage in the heads,so emissions may be a problem for you too if you have to have it tested.
its a good stock head if your on a budget.
Old Nov 13, 2010 | 01:25 PM
Car: 1986 Iroc-Z
Engine: 355
yeah i was talking about the piston brand, looks like everything checks out then thanks for the reply guys.
Old Nov 13, 2010 | 06:58 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Sealed Power/Speed Pro= TRW,been around darn near as long as the internal combustion engine.
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
Linson
Aug 21, 2015 02:12 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
