1986 trans am 305 to 350 tpi swap
Old Dec 10, 2010 | 11:04 AM
04nismo's Avatar
Car: 2004 nissan sentra SE R spec V
Engine: 2.5
Transmission: 6 speed
ok my friends dad has a 1986 trans am that has been sitting for about 10 years. so i ask him what he wanted for it and he says 750 bucks, ok not a bad deal, he says he has a 350 motor to put in in with the tpi. what all will i have to do to make this car run and about how much will it cost. sorry if someone has already ask this question, and btw the 350 is just a block right now but he says he has everything to put it back together
Old Dec 10, 2010 | 04:21 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Re: 1986 trans am 305 to 350 tpi swap
Welcome to Thirdgen.org first of all. There are threads in this same forum that can answer most of your questions. Why not start there?
Old Dec 12, 2010 | 03:21 PM
xcoltonx's Avatar
as long as you can get the ecm and wiring harness for that correct engine it should be easy to make happen. price depends on what he already has and will give you with the car... could be looking at thousands if he has little to nothing
Old Dec 12, 2010 | 07:45 PM
Davidgou's Avatar
When your friend says he has everything to make it happen, what does he mean? Can you list the things he has so we can help you with what you might need?
Fast355
Dec 2, 2016 06:33 PM
beachrodder
Aug 25, 2015 08:05 AM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
mizz0313
Aug 12, 2015 06:45 AM
