350 build
Old Dec 11, 2010 | 05:50 PM
jimc1987's Avatar
Car: 1987 pontiac trans am
Transmission: 700 R 4
350 build
Hello all i am going to be bulding a motor to put in my car its a 350 from a 74 chevy truck and swapping it out with my EFI 350 thats in my ta now (going to put that in a camaro) this is my first build just wondering what i should all put into it i want a good solid motor to run good and produce some power but still drive on the street i basically want some ideas and any problems i could run into thanks guys
Old Dec 11, 2010 | 06:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 350 build
Has it been rebuilt since 1974? What heads are on it?
Old Jan 27, 2011 | 10:35 PM
jimc1987's Avatar
Re: 350 build
well a little update i have my moter at the machine shop my block is getting bored .40 over and my crank is going to be grinded .10 under i have gotten new cast vortec heads and rockers and all msd setup but i do have kinda a wierd question im new to the rebuilding proces im thinking bout getting new rods would i still get .10 under bearing with the new rods i know its a newbie question but im just wondering thank you everyone who posts
Old Jan 27, 2011 | 10:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 350 build
The diameter of the rod doesn't change, just the diameter of the crank pin.
Old Jan 28, 2011 | 09:11 AM
jimc1987's Avatar
Re: 350 build
ya thats what i thought thanks for responding this is my first build so i just wanted to make sure
Old Feb 4, 2011 | 11:14 AM
jimc1987's Avatar
Re: 350 build
so what are you guys running for exhaust im thinking bout doing duels how hard is it to run with our cars also until i get the exhaust done what should i leave it open headers or not i wont be driving it alot
Old Feb 4, 2011 | 05:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 350 build
If you attempt to do duals, do 2.5inch or smaller over the rear axle. Everyone tries to do dual 3in+ exhaust all the way back, which is silly - 1) 3's don't fit well and thus drag on every little speed bump, driveway entrance, and pavement crack, and 2) dual 3's = 6 inches, there's no one driving on the street, regardless of motor, that needs 6 inches of exhaust for any reason. Dual 2" would fit nice, give you 4" of exhaust (way more than your 350 will need), and if you want to look like some bada$$, you can put tapered 2" to 3" tips on the end.
If you have 3in collectors, then transition down to 2 or 2.5 before the axle - maybe even sooner - most 3"+ exhaust I see on 3rd gens drags the ground where a Y pipe would normally be. Maybe it looks cool on the shop lift, but sucks for everyone on the street. It's no good having an extra gazillion hp from free-flowing exhaust if you can't drive over 25mph anyway for fear of knocking that cool exhaust off the car with a slight dip in the road! I'll win a street race everytime with my sad old 350 and single 2.5" exhaust, over any other 3rd gen on the street regardless of motor/hp numbers, if I pick a road with a few dips in it
Old Apr 25, 2011 | 02:19 PM
jimc1987's Avatar
Re: 350 build
Old Apr 25, 2011 | 02:25 PM
jimc1987's Avatar
Re: 350 build
there she is my motor its been done for a little bit but finally got around to putting up pics but heres what the motor has ok its a 350 block with scat rods flatop pistons comp cam (461 lift 232 duration) vortec heads edelbrock intake edlebrock 750 carb all msd ignition im sure im missing some stuff but u know according to a computer program i am making about 400 horse but i thought i would throw a pic up for u guys
Old Apr 25, 2011 | 02:56 PM
85_ZED28's Avatar
Car: '85 Z28
Re: 350 build
Looks good! How does it run?
Old Apr 25, 2011 | 03:08 PM
jimc1987's Avatar
Re: 350 build
it runs good it sounds good and its a blast to drive alot better than the old motor. I do have a question for people what is better i need to do something about my fan because i cant put my hood on cause the fan is too big so should i go to jegs and get a smaller mechanical fans or wire up my old electric fans
Old Apr 25, 2011 | 05:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Wire up the electrical fans, get rid of that engine driven fan.
Old Apr 25, 2011 | 06:20 PM
hornick's Avatar
Car: 1986 Trans Am WS6
Engine: 305TPI
Axle/Gears: 3.42 (I Think)
Re: 350 build
agreed stick with your electric fans!
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NWAsonoma
Aug 18, 2015 05:45 PM
sreZ28
Aug 14, 2015 07:48 PM
